Linking the Philio Tech PSR04 to control lights
Jørgen Skår Fischer shared this idea 10 years ago
I have bought a philio tech PSR04, and it gets included on the network, but i cannot ser that it sends info when using it.
Have anyone else had luck using this?
Replies (6)
Where have you bought it? I am looking for it for months.
https://www.tronika.no/en/zwave-controllers/865-wall-controller-psr04.html
I bought it here, a norwegian web-store. The device seems to work ok, i just cannot get ZipaBox Duo to recieve the events ;(
It registers just fine, but then nothing.
This is the first controller / wall switch i have bought. Just trying to get it to work on/off with a fibaro wall plug at first to test the concept.
I get NOTHING in the controlpanel when using it.
Could you please provide some screenshots of the device manager and the puzzle creator?
Example:
b6273e9437151ac430a1b29d944288e4
6a296abe34bc51eea1f2dde2ab9f78c4
As a drastic meassure, i have removed all my NEXA (433mhz) sensors, devices etc, and now adding on just the two i want to test.
Below you can see what i have :)
a98a7ce651734e827caeb98dbf9c0b4eb318dc1b7117f0920f3a53897c8042db
Issue seems to be with the ZwZwaveLevelControlMlvlSwitch -> I cannot seem to access it to edit its properties -> Maybe a faulty config? I have tried deleting it, and adding it again, in both the states that the controller supports (timer and dimmer).
hmmmmmmm
After removing it / adding it again i got this error:
Device found.
Joining device please wait.Join not successful.
MANUFACTURER_SPECIFIC_REPORT not received
