Virtual Thermostat and deshumidification or ventilation, how does it work ?
How can I use this function ? How does it work ? I have only temperature informations to set and no H° values.
thx
Need to humidify here soon too so I need to know too.
need a ventilation button and triger by temperature or an other sensor
This is not clear.
What is the entry and what is the exit for ventilation. How do I use the timetable?
How do I use the widget?
I want to ventilate depending on humidity and time
This is not clear.
i tried to make my ventilation work automatically via the virtual thermostat pro.
i used a multi sensor as an hygrometer input to see the humidity level off the room.
i also used a test switch to activate the output manual and used a virtual swich as an output to test it.
i have set the humidity levels to 60% in the api but if it goes above 60 it does not activate the switch. When i activate the manual input the output does also not activate
So how do I need to set it or does the function not work at all?
Hi, it is yet not implemented, ever since the beginning. I asked this year ago. Perhaps one day...
