Devide Limit Exceeded!
David Rexander shared this problem 9 years ago
Why cant a install more then 18 devices? The device manager says the limit is 20(???) and I only have 18 installed. And why don't zipato support more then 20 devices?! I have now look everywhere but i cant see where you say that the only support only 20 devices that was a real disappointment.
But the biggest is that i don't event can have 18 devices of 20 before it cries out of needing money.
Replies (6)
Create a support ticket. You should have unlimmited devices as you have a box before v1.0 software.
still 20 is pretty limited
I dont even know how can you end up with 18 (20) as limit. For zipabox is unlimited. Zipamini is 5 devices. To upgrade you get 1, 20 or unlimited so overall 29 does not add up...
Have the same problem !
My devices shown don't match with eachother either, maybe is same case with you?
Device manager says 24 devices.
6854f21d2a8e074a0b4e9c8d7b3f5fe1
But when I then click on the Zipato name, it says 32 devices....
17e1a0a07465153447dd307f937594d8
Maybe when you click on that name it shows 20?
in the second image it also adds the virtual network modules.
so then total devices is virtual network devices + Zwave devices.
