How to create a rule "DO something when value of thermostat setpoint changes"
Stefan shared this question 10 years ago
Hi Folks,
I am not quite sure how to get this done?! Here is what I want:
I am using a temperature room sensor (Danfoss) with which I can also change the set temperature. I want to create a rule which perfoms an action every time the set temperature value changes.
In the rule creator I can "only" define a "WHEN" rule, insert the danfoss as a sensor and then choose an attribute. Here I can choose "heating setpoint". Does this already means, that a reaction is caused every time the setpoint changes?
Or do I have to user another kind of rule to make an action based on sensor change?
Thanks,
JD
