Qubino Shutter Control (Class C Motor Control ZMNHCD1) can not be set as Shutter
Dear all,
I have succesfully included 3 Qubino Class C Motor Control ZMNHCD1 as shutter controls to my Zipabox, but they turn to be recognized as light control.
Switching to shutter type is possible in admin panel (but not in mobile app), but is nayway not taken into account when synchronizing.
Could you please advise and make it appear like fibaro ones for example ?
Stéphane
I hade the same problem with a qubino shutter control, after som discussion with the support they releaed a fix for it.
Suppriced to see that you still have the problem since i think it was a general fix. You should start a case with the support
You can refere to my case (was for qubino DC tho but same problem)
my ticket number SLE-235-51486
//nic
//nic
Hi Nic,
Thanks for your reply (and confirmation), I opened a ticket to support.
I guess this device is slightly different from the DC, that's why previous fix does not work.
I'll update the topic once issue solved and solution provided.
Stéphane
Hi Nic,
Stéphane
