COCO AGDR-3500 / AGDR2-3500R
Maik shared this idea 10 years ago
Does the Zipabox work with the COCO AGDR-3500 / AGDR2-3500R?
You can try to upgrade to the latest beta firmware release and try to include your devices as CoCo AC-1000.
They might work although we did not test them yet
The AGDR-3500 works at the Zipabox.
I have added the AGDR-3500 as AC-1000.
Ok thank You :)
Today, i Test it and it works Perfect als Coco ac-1000.
I have the same issue. I can add the coco 3500 device as ac 1000 an nexa or chacon, but I am not able to control or switch on off the device from my zipato. it has got no endpoints, even though I can hear the clicks of the device while adding to the zipato.
Downloading the beta version of zipato does not work either, there is an pop-up to update but nothing in it to click
on the left side of your web browser, in the device manager menu, there should be a controller icon. Select it and in he submenu select firmware -> upgrade to latest beta. Do you see that?
When you upgrade to 8k version, everything should be fine.
Do not upgrade to 8k if you have alarm. It will stop working along with most of your rules
Ok. I totally missed it. Now the device and all the other rules are working
