Zipato RGB Bulb
Does anyone use the Zipato RGB Bulb? I'm confused with how the bulb is different when using it through the interface and when using it in the rule creator.
If I open the device and press the "White Mode" button, it's different than when I choose "White" in the rule creator. Meaning the bulb is actually a different color. I've played with color temperature and intensity but can't get it the same.
Does anyone know how to match the White Mode using the rule creator?
This is a bug and is not possible.
So the Zipato bulb isn't completely compatible with the Zipato Controller?
I guess I should have known...
Thanks.
