Away function is overruled by the thermostats own progtm
I have made a a set rules, so when ever I arm the alarm, it puts the thermostats into the away mode. That works fine until the thermostat changes into a new mode setting (eg. comfort or so) according to it's own schedule.
Is there anyone who knows a work around or a method to get the thermostats in "Away mode" when ever the Alarm is armed?
try adding a "set" puzzle block with the thermostat after this comfort puzzle to permanent hold
I've tried to make a new rule (not in the same rule, which sets the thermostats to away) but in a new rule, below, which set the thermostats to "permanent hold", so lets see how that Works.
