How to include thermostat into a scene?
Eric T. shared this question 10 years ago
I would like to create a scene with a thermostat. IE "Going back home after dinner scene", which would raise the temperature in bedroom and bathroom by 3 degrees for instance. In the scene creator only on/off switches are to be found, no thermostat. Am I missing something? Is there a workaround?
Thanks.
Use a rule to set the values on the thermostat then activate a scene at the same time for your lights if needed?
You can create a virtual switch to run/execute the rule.
