Failed to update box settings. Cannot set temperature scale to degF
trebeard shared this problem 10 years ago
In the "controller settings" tab in DeviceManager, I'm trying to set the temperature scale to Fahrenheit. When I make this change and then select "SAVE", I receive an error "Failed to update box settings". How can I resolve this error and publish my temperature sensors in Fahrenheit units?
You might not want to waste your time trying. Even if you get it changed, it still doesn't work correctly.
Mine is set to Fahrenheit, but everything is still shown in Celcius.
You need the latest BETA to be able to save the Settings for the Temp but indeed as Nathan points out below it's a bit variable with inconsistencies between the Web GUI and mobile device.
