NodOn OCTAN remote / Not working after each reboot/shutdown of the zipabox
Gizmodu74 shared this idea 10 years ago
Good morning,
I use an Nodon Octan remote to control my lighting with 7 rules wich run some scenes in the Zipabox
The remote work fine after the inclusion and the setup.
The problem is that each time the zipabox is switched off or rebooted the Remote stop to work.
The remote still visible in the interface, but nothing happen when I press a button.
I'm oblige to exclude and include again the remote and I'm oblige the modify all rules (7 in total in my case) to re-activate the remote in the scenes. After I do that it works again.
The problem is that it's tooks too much time and it's not confortable.
Do you know a way to keep the remote programmed or to "reactivate" it easely ?
I'm using the official firmware 0.9.999.8Thanks in advance for your support.
The problem was solved after update of the firmware to the latest beta firmware 0.9.999.8k.
Thanks to the Zipato support team for the solution
Same problem for me.
I will try to update to the beta firmware to check if it helps.
