ZIPABOX and Marmitek X10 AM12 receivers
Stéphane.G shared this idea 10 years ago
Hello
I bought a ZIPABOX controller for one week.
Now I try to use my old X10 receivers thru the ZIPABOX RF433Mhz Module
1) I have a Marmitek TM13 RF Module I really need to connect to the ZIPABOX controller.
How to proceed ? This material is not listed in the X10 compatible products.
The goal is to manage the AM12 power receivers thru the ZIPABOX...
2) I also have a Marmitek USB/Serial CM15 interface.
Is it also possible to use this one ? how to do ?
Thanks a lot for your answers.... I'm lost...
You should be able to control your AM12 through zipabox using CM15. Just connect CM15 to the box, restart the box and try to include your AM12 using old web UI (not new UI). If you will have some problems contact support@zipato.com
Thank you for your answer, but how can I connect the CM15 ?
Is it possible to use only the TM13 ? if yes, how to connect ?
(I would like to ignore the CM15 if possible)
Best regards
You need to have serial or back up module to connect CM15 via USB port
