One tablet for several users
Guest shared this question 10 years ago
I would like to use one tablet (one user always logged in) for accessing the system.
With this tablet I could like to control the alarm (besides control devices and sensors).
The account logged in can do this with his/her PIN but what I could like to do is that all users can arm/disarm with there own PIN without changing user.
Is this possible in any way?
Other alarm system have this function - just use your PIN and you can arm/disarm.
/Tobias
you can use different codes, even if you are logged in as one user, so long as you have internet connection.
Another option is to create a virtual switch to arm and disarm, then use imperihome. Each icon/device in imperihome can have a lock code to use. This would allow you to have two or more separate switches that can have different codes.
This is not possible for me... I get error message when using PIN beloning to user not logged in. If I use my own PIN when logged in it´s OK.
Any settings?
Any ideas on this?
Never tried this...
Look at the user (in the dashboard)
Fill in the pin
Make sure that the alarm checkbox is on
Then try again.
