Working rule with scheduler and time restrictions
Reidar Østrem shared this question 10 years ago
I'm struggling to get a rule working that will be restricted to weekdays and between defined times.
I've tried almost every combinations i can think of.. Last time i tried the rule looked like this:
When Scheduler (Repeat, Weekdays)
If time now between xxx and xxx
If Sensor Open
Action send message
Could someone post a working rule with the scheduler ?
Regards,
Reidar
Can you explain what you want to do?
Try like this:
When Sensor = Open AND Part day of week OF (now) = 1 or Part day of week OF (now) = 7
etc
Hi HeroS,
What i'm trying to do is restrict push notifications when a sensor is triggered (OPEN).
The restrictions will be weekdays between 07:30 and 16:00. Should be simple enough, but i think i have tried every single combination with the scheduler and time but no luck. Therefore if someone actually have a similar working rule, it would be nice if they shared it.
Regards,
Reidar
Try this:
etc
make sure that the sync is working (use the API).
