thermostat basic feature not working
Mauro Delrio shared this idea 10 years ago
I created a thermostat
5861a36348b5af80d9d463e6d12da10b
create with no rules for temperature, just static 22 degrees
78c815dd8af24703f837a270c224b0f7
but for some unknown reason the log show recurring temperature settings variation
fc3fd6a6ca3a10ff014334b32e6b1a23
any help ???
Hello Mauro,
In order for your thermostat to work correctly you will need to set correct device as "Thermometer input" which will send current temperature to your Virtual thermostat.
Sorry I posted an old screenshot...
this is the current configuration
2ac9b82325c52f0f2029ee3e709816a7
I'm also wondering about the reason why the program mode is always OFF after some time.
I need to manually set to AUTO...
2b8cc0bc3517beecaa35a0f64c01c3a8
Hello Mauro,
If you are using only one thermometer as an input please use function "Last". Try again after you save your changes.
