Is Foscam cameras supported?
Thomas shared this problem 9 years ago
In Progress
How do I know which Cameras that are supported? I want to buy supported products!
Regards,
Thomas
Foscam work.
I have tried to install a aFI8906w and a FI9821w v2 but they are not found when running camera scan. And when I try to add them manualy I doesn't work. Is it something special I need to configure?
add manually, then add this to fields:
High quality stream: rtsp://USER:PASSWORD@192.168.1.XXX:XX/videoMain
Low quality stream: rtsp://USER:PASSWORD@192.168.1.XXX:XX/videoSUB
snapshot: http://192.168.1.XXX:XX/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
Change, XXX:XX to the correct IP adress for your camera and :XX to port, probably 89 if you did not change it. Also change, USER to your username for your foscam setting and PASSWORD to the password for your foscam password.
you also need to go to your Foscam settings, enable FTP storage for snapshots and then fill in following info:
FTP: ftp.zipato.com/snap
use then generated username and password from your cameras settings page in my.zipato.com
Hello,, snapshot seems to work for 8921w V2 but can't see the streams in webgui or in the android app. Is that working for you?
Iam not sure if it will work for 8906W, but it will definitly work for 8921w V2, i have to of those
Dear Thomas,
Fully supported FOSCAM Cameras:
IP Camera Foscam C1
IP Camera Foscam FC1403P
IP Camera Foscam FC2401P
IP Camera Foscam FC2403P
IP Camera Foscam FI9804W
IP Camera Foscam FI9821W V2
IP Camera Foscam FI9826W
IP Camera Foscam HD816P V2
IP Camera Foscam IPV38P2P
If you still experiencing issues, please open a ticket on our support site: support.zipato.com so we could examine this directly on your box.
Pero Zovkic
