Rules stopped working
Hi!
Two days ago I added a couple of more NEXA WMR-1000 and made rules that they should set on when dusk.
At the evening nothing happened and the next days I saw that none of my other rules hade worked. It seems that everything stopped working after I made the new rule.
Do anyone have any idea what the problem might be?
Seems that i put the question under wrong topic, maybe someone can move it?
When you add a new rule which is faulty, NO OTHER rule will work!
See the knowledge base entry:
https://community.zipato.com/knowledge-base/article/rule-malfunction
Thanks! I will try to remove my new rules.
When I removed my newest two rules and sync then it worked agian. Then I tried to add my units to another already existing rule, that worked, all rules stopped working.
I don't know what I have done wrong. I have made something lika 30 rules and never had this issue before is it me or is it something wrong in the latest firmware (I'm running 0.9.999.8a)?
Post your simple rule that stops the rest to work. Root/parent devices cannot be used in the rules.
What do you mean by root/parent device? The device is a nexa wmr-1000 and I have tried a couple of different rules for it. I even tried to add "Handling on" and off for it in some existing rules that I'm sure worked before. I'm not fully sure yet but it seems that if I try to add a new rule or change anything in an existing rule everything stops working.
That makes me wonder if it has anything to do with rules for the new devices or if this isn't a software issue.
A side question, if one uses the rule creator can one create a faulty rule and sync it so that everything stop working?When I try building different rules I usually always get a message if there is something is wrong.
