ZXT 120 +ZIPATO
Zipato guru shared this question 10 years ago
I added IR infrared ZXt 120 successfully but in the app when i use it through the zipatoo app after learning the code of the air conditionner i found only command with number from 1 TO 20 so that i can't know from the app which number switch ON and off , which number raises the tempretaure.
For Exemple i set NUmber "1 "for "ON ":
IN the app thow to change the number"1" by the word "OFF " written instead of it .
THank you in ADVANCE.
This happens on the current apps.
if you use android, try the new beta app and you can see that the names appear as you want.
so what is the solution for that not logic must our clients change their smart phones from IOS to android what is the solution?
Just saying what I noticed. For what I've read in this forum, the new app will be released sometime this year on all platforms
thanks
