X10 extended support
Mink shared this idea 10 years ago
I have a CM15pro attached to the USB/serial module and the only X10 modules that are supported are the AM12 and the LM12. It would be very usefull if extended X10 is also supported. Two-way micromodules like AWM2P / SAIX12 and LWM1P / DAIX12 can send a status to the CM15pro and the dimmer modules kan receive exact dimlevels.
