Push message
Hello, what do i need to do if I want to use "send message" to push inone of my rules. I have seen some instruction for setting upp push with http request but not to use the send message.
You must change "E-Mail" to "Push" in the top of "send message"-configuration...
Yes, I understand that :) But do I need to do any other configuration to make it work? Do I need to install some other application on my smartphone?
The Zipato App must be installed on the Smartphone :-)
Ok, and thats it? I just tried to change that but it didn't seem to work. I will give it another try.
And you must be log in of course...
I made a rule that should push a message when a sensor indicates movements. I have the zipato app installed and I can communicate with my zipato. But it don't get any notifications even if I see that the sensor indicate movments.
Hi at all! I have the same issue. I use a Vision garage door sensor that work properly with email notification when door is open/close. But since I changed notification mode from email to push, I didn't receive any notification.
Same here. I receive emails, but no push- and SMS-messages at all..... is there any documentation about?
I think a 3. party service like Pushover is better. I use it for many different things also for other stuff than Zipato. It is possible to send push messages with different priorty (like alarms that needs to be confirmed), diffent sounds, force loud alert sounds, use http links, custom images and more.
You will have to call it with a http request from your rules.
Just my 2 cents...
Just my 2 cents...
Hello guys,
as already explained you need to select Push in a send message puzzle and be logged in the Zipato app to receive a push notification. It is a good idea to double check if you have entered the correct phone number with your country calling code. Also please check if the notifications for the app are turned On and just in case check if sync of your apps on your phone is turned On, it is by default but you never know.
You can also check this article in our knowledgebase - Receive push notifications via PushingBox and Newtifry
https://community.zipato.com/knowledge-base/article/receive-push-notifications-from-zipato-controller-via-pushingbox-and-newtifry
Hello guys,
Thanks a lot for a useful hint Anonymous, it works for me!
In my case, the phone number was crucial.
Thomas, the settings for notification from app's is under Android settings. Check the settings for Zipato app.
