Z-wave Warning "Device, endpoint and cluster names will be reset to default values"
David Pritchard shared this question 10 years ago
If you go to "configure node" in a Z-Wave device you get the warning "Device, endpoint and cluster names will be reset to default values". Does this mean that you can't even inspect the current configuration? Is an instant reset carried out?
