ZIPABOX+IP CAMERA
Zipato guru shared this question 10 years ago
Hello;
I included my IP camera to zipabox on the same IP adress.
Later on if i use my ip camera on a such IP adress and the zipabox that contain the included camera on another IP adress could it communicate to the camera?or they should be both on the same IP so that to get the camera working?
Thank you
your zipabox and camera should have a different IP address. Both should be in the same network, 192.168.0.xxx or 192.168.1.xxx
Best is to put the camera on a static IP or else your router might give it another IP and it will stop working.
