Some questions about QUBINO ZMNHJD1 Dimmer DIN
Philippe Chiron shared this question 10 years ago
I have some questions about the module QUBINO ZMNHJD1 Dimmer DIN and Zipabox:
- I can't find the list of custom settings module by clicking on the Configuration tab, but "custom configuration" with the possibility of adding new (description / param / size / value). I think changing the settings might solve some of my following questions. How to do?
- Once installed, the module is represented in two forms: Inter on/off and dimmer. If I operate inter example to off, the light goes off well, but the web app (or IOS) takes a long time for the inverter starts at 0%. Same if I switch the drive from 0 to 100% in this case, is the inter on/off that is slow to move to the correct position.
- More annoying By acting on the physical push button: Switch from off to on, the light turns on, the drive on the app increases to 87% and not 100%. Thus the inter on the app remains off.
- Creation of rule, there is only one icon for the module (I would have thought that since it is both on / off and dimmer, there would be two). But what bothers me is that it was named "Root device: lifelive" and I can't change this name which is very annoying because if more modules are installed they are the same name and it becomes very difficult to distinguish. These modules have yet been appointed différament when combined and in the properties.
- In the case of action by the push button, you can not obtain a variation, only on / off.
Well, the list is long and I hope I have not been too confusing in my explanations. and my bad english
Philippe
