Schneider connect 4 pole switch problems.
Jacob Wiqvist shared this problem 10 years ago
I have some problems with my Schneider Connect switch.
No dimmer command in rule creator and a problem is detected in device manager.
I added it to my Zipabox and the inputs work but. But there is also a level function for dimmers that do not work. See picture. Hope this function will work?
No configuration under the switch?
A yellow dot in the device manager reporting a problem with the switch.
3e720ee0c0459afc394e43f3d6cdc141
Replies (6)
When will this be added?
I have 180 euro of equipment in the hallway. Schneider connect switch, Fibaro dimmer 2 and Schneider Exxact series Switches.
The only thing that works is one button on the Fibaro dimmer. So the second button does not work and the Schnider connect switch does not work. I have also waited years for the Nexa WTE-2 switch to be implemented. Zipato tried but could not implement it correctly. Meaning You have to push the switch 10 seconds to get the command sent.
To have 3 different inputs that not work is not ok.
And I don't know what to do?
I have the second button on two Fib dim 2 working. How does your's behave/misbehave?
I have this working..78580abda094d54e453091175c5eafa0
My switch also worked befor. Now it does not?
What box version do you use?
Q...
Any way anyone can se the video. It speaks for it self.
