push notification
Zipato guru shared this question 10 years ago
HI everybody;
I've created a rule that send push notification using rule creator it worked fine for the 20 hours and then after many push notification i received on my Iphone i no longer receive any push?
Is that problem related to their cloud' zipato cloud) or their server?
Or is it a big from zipato dash bord?
Does any one had the same problem
Thank you all
How did you write the push notification? Which rules and blocks
thank you navid it's right now
Hello Hani,
Also please make sure you are still logged in Zipato application with
owner or member account and the same account is set as recipient in rule you
are configuring.
it's done thank you
