Qubino DIN Dimmer (ZMNHSD1)
I can include the DIN Dimmer without any problem. But after the including process is finished the DIN Dimmer ist offline. In Device Manager I see the Dimmer as Qubino Power Switch Multilevel. Under type: undefined
Has anyone the same issue?
I have had the same issue with Schnnider Exxact Connect Switch.
I wonder what that is?
It is possible that this two devices not supported now.
But as I understand it z-wave devices should be more plug & play. Why is very few devices not that on Zipabox?
Almost every device needs to be configured by Zipato???
http://www.z-wave.com/about
answer from zipato support:
I have just made the device descriptor for the Qubino DIN dimmer and it should now work properly with the available configuration.
