Timing issue
I have a motion sensor in the kitchen, and when it senses motion, it needs to switch on the kitchen light. I got that bit working, but I only want it to switch on those lights between 6:30am and 8:00am and 17:00pm and 22:30pm. No matter how I make the rule, the lights never come on.
I use the time <now> between 6:30 and 8:00 and time <now> between 17:00pm and 22:30pm blocks, but it seems these are not working?
Could someone show me a rule that would work? Below a rule i made:
Try use the OR function instead of AND, as you have it now the rule will only run if the time is both between (06:30 and 08:00) and (17:00 and 22:30) at the same time.
