Devices not showing in Rules Creator
Einar Kobro shared this question 10 years ago
I have now just unpacked my brand new Zipabox and some accessories. I have added Fibaro two wall plugs and one Fibaro smoke detector. In Control Center, I have 3 devices. In Rules Creator, I have zero devices.... Yes, I have refreshed, several times. The Devices Tab is completely empty, no Actuator, Alarm, no nothing...
Maybe this is a newbie error, but I'd be happy for advice. Cheers!
Disregard my question... Closing the browser and reopening solved the question.
Is this how the update/refresh procedure should be....?
You need to make sure that you synchronise after making any changes. Confusingly, there are two identical-looking sync buttons, on the left and the right. The left one is for device changes, the right one for rule changes. Make sure you use both as needed!
Thanks David. I'm quite certain I used both synch buttons more than once, that's why I was a little confused and posted the question. But now stuff is working! :-)
