Danfoss compatibility list
Hello, i am still using Danfoss link solution, but i would like to change it to Zipato system, may i find somewhere if these products are full compatible ?
Danfoss Link BR
Danfoss Link FT ELKO
Danfoss Living Eco
Danfoss Link PR
i am most concerned about BR Boiler Relay and FT ELKO floor heating
many thanks
Ed
Living Eco Thermostat isn't supported since Danfoss uses it's own protocol in this device. No Z-Wave. Only The Living connect thermostat supports zwave.
Don't know the other devices.
Hi, many thanks, i didnt know it because i have read this : https://community.zipato.com/topic/thermostat-danfoss-living-connect it is another model ? Thanks
Update : I have only Living connect, not Eco
Even Living connect has various versions. Some may only support the Danfoss Zwave system and will not work with other gateways. Which model number you have? Living connect ending with 12 or 13 are the only ones that are other gateway compatible...
Thanks, i will check it first, if valves will be OK then i can in worst case replace boiler relay, but replace all valves (10 pcs) would be too much :-(
OK i definitive have LC13, so compatibility should be OK, new Zipabox ordered, thanks to all !
