Where I can find a roller shutter position in API?
Guido shared this question 10 years ago
I control some Somfy RTS roller shutter with my Zipabox and the 433 Mhz Somfy Controller.
The problem is that the actual position in myZipato is wrong if i use sometimes the Somfy controller.
Now i want to listen the data transfer of the RTS signal with an arduino which i control with my Raspberry Pi to know always the right position of my roller shutter.
From my Pi i want to get this information to the Zipato API. But i can`t find where zipato save the actual position of the RTS roller shutter.
Some ideas?
No ideas?
You should go into device manager, expand the network in which your roller shutter is, expand that device, expand its endpoints and clusters until you find an attribute called POSITION. Then click the little gear icon next to it and on the bottom you will see its UUID, copy that.
5a92bd2782e872b5bf2c1a6cd6fd0179
Now you can use that UUID to get or set the value via our API.
