Before i start
EddieCz shared this question 10 years ago
Hello, i have read all instructions about setup. There is written: If you add new device, controller should be near this device, cca 1m. Now technical question : Has controller to be connected to internet ? If yes, i see it little bit complicated to go to all places with thermostats and all other devices with long power and network cables. Is it so or i did it wrong understand. How did you manage this ?
Many thanks, Ed
If short inclusion is not always possible, try to link at least the security devices (like sensors) as they need it in order to be linked via the security inclusion. The rest just include as you can.
I have only thermostats and ventils, no security.
Being near to the Box when adding devices is a major issue when the support say "Try to remove and add again the device" and the device is wall mounted...
For new devices I usually add to the network before putting in place and after the installation I performance a "network heal".
