Zipato camera/WiFi
Mel shared this question 10 years ago
Documentation says that the Zipato IP Camera has WiFi capability? If that is correct, how do you make the WiFi connection? I already have the camera operating, but am using a CAT5e internet connection to the router. I rather be using WiFi.
Connect to the camera with web browser. Go to "Set Up"->Network->Wi-Fi.
Select Enable ON->Press Search->Double click on network when appears in search results->Configure WiFi/Enter password.
Zipato Team
I have done all this before. However, I did not open/load the plug-in that it shows to do when you click on Video Mode 1. Is that what needs to be done or is there something else that seems to be a problem. It keeps saying that the Test fails.
