What are the releys/on/off in the Zipatile for?
Christoph shared this question 10 years ago
In the Zipatile there are 2 relays you can switch on/off...
I'm wondering what they are for an how I can use them...
Heating control. These are dry contact outputs that you can connect to gas or electric heaters or perhaps even heat pumps if they support heating control. One can be a heating control and another a cooling control...
That is the idea. Globally u can even use them as switches for any electrical device up to 1A. You only need to connect L to it, but must make sure it will not be more than 1A (use a fuse for example).
wow, awesome as an intecom unit, the contacts can be used in conjunction with a touch button for a gate/electronic strike release.
