Use of Homematic / Homematic IP devices
Guest shared this question 10 years ago
Is there any possibilty to use Homematic or Homematic IP devices with the Zipabox?
I don't think this will happen soon. There are many different more common device that have priority in the list. Do these have open API at all?
There is an XML-RPC Api for the Homematic Controller.
There is a XML-RPC Api for the Homematic Controller.
Are there news on the development of the connection to Homematic (eQ-3) devices?
any updates here?
Homematic IP you can connect through conrad connect . They have integration of Zipato and Homematic IP and if you want to use Homematic then it is possible to use Cloudmatic with conrad connect.
The problem with these services is that not all Homematic devices are supported.
Hope that helps.
Beat
Hello Beat,
yes, that helps.
It is a pity that the Homematic IP is not compatible without detours.
Puya
