Some rules stopped working
Johannes shared this problem 10 years ago
One day suddenly, without me doing anything or adding anything some of the rules seems to have stopped working.
I've tried to disable and sync and then enable and sync, did not work.
Then I tried to delete the rules, sync, make new rules and sync. That did not work either.
Now I don't know what to do. Any suggestions?
Dear Johannes,
during the Rule(s) synchronization all of Rules are complied into one
script and downloaded to the Zipabox from Zipato Cloud Server. Because
of this, if there is one invalid rule, java compiler will fail during
the rule synchronization and a whole script will become invalid.
In that case Rules should be examined for an error and the best way to
debug is to disable last modified or created Rule. If invalid Rule is
disabled and synchronization is repeated, script will pass Java compiler
and Rules will become operational
