Nuki
Guest shared this question 10 years ago
Is Zipabox able to work with Nuki https://nuki.io/ ?
I don't think it could work with it since it's bluetooth tecnology, maybe zipatile. Unless you use the bridge you probably could use http commands.
I have a couple YALE locks that work similar but with Z-wave, they work pretty good even though YALE claims they have more capabilites than what Zipato is using. You can even create geofencing to open it automatically.
http://www.yaleresidential.com/en/yale/yaleresidential-com/residential/yale-real-living/
There are also more brands like Kwikset, Danalock, etc...
http://products.z-wavealliance.org/regions/2/categories/6/products
With the bridge you should be able as the API of Nuki is pretty staight forward.
