Zipatile Intercom (SIP Server)
Duccio Rosselli shared this question 10 years ago
Hi all,
is anybody using the Zipatile SIP server to connect to a SIP Client in any way? I'm trying to use the SIP Server and connect a SIP client on my Android phone to that, but it doesn't work.
Any idea?
How do I configure the SIP server on the device?
Duccio
Replies (34)
Hi Petr,
I guess you will have a device in your apartment with a button to open the door of the main entrance.
It might be possible to use a Fibaro Universal Sensor. With this sensor you would be able to have a "switch" within your zipato system to open the door.
Several other larger sensor would also be able to do the job like the RGBW module from Fibaro.
For as far as i know Fibaro will also release an intercom module but that would not fit your requirement.
Hope this helps
Regards,
Slashroot
We are currently working on 2N integration. All functions requested will be available. ETA is October.
This is an unknown territory to everyone. Apparently ZipaTile should or would support 2N IP doorbell systems, but I have no idea if this has been finalized or not yet implemented...
Lets wait to Zipato to answer this.
yes I think they started with a Helios model, and hopefully they have integrated the Doorbird now.
I have mobotix door station t25 and looking to integrate these together. I would be greatful for some manual or instructions too.
Thanks in advance
Any news? I´m pretty frustrated with finding a working system for a doorbell intercom with or without video...
The Video could be upgraded with the new Zipato cam indeed
Did you get the Mobotix running on the Zipatile?
3
Integrating something cheaper would be nice though...
1.5k€ for a single doorbell?
No thanks...
Look for Hikvision door entry system. It also supports sip so we just have to wait until sip is integrated completely zipato
Yeah, but when will this be done... :)
Zipato Intercom is very complex system, so it is still in the process of testing and debugging. Hopefully, we will publish the beta version by the end of this month or begging of October.
Regarding functionality, Zipato Intercom will be based on Zipato SIP server and Zipato SIP clients. Zipato SIP server will be available on Zipatile and in cloud. These will be back to back connected in order to allow communication between Zipato clients within a Zipato network. There will be possible to use various external door phone units with Zipato SIP server, but right now we are only testing with 2N Helios.
More info will be available soon...
Begin of October was a month ago.
What's the actual situation?
Sebastian, 2N Helios can act as a SIP server as I know. You just need to install the free 2N Android client on Zipatile. We tested this kind of configuration with a Comelit Sense doorphone and its client on the Zipatile and it was ok (even while the doorphone was in another city 500 km away!!). Forcing to run a SIP server on an unstable device (like Zipatile which randomly restarts) should be avoided in my opinion. Let the doorphone to be the server.
  1. 1. Zipatile is not unstable! If it is restarts, you have an issue with the internet or Zipatile itself.
  2. 2. 2N Hellios door phone doesn't have SIP server built in. You were probably using client to client connection which is only working between door phone and single client.
  3. 3. Zipato Intercom is complete building communication system with multiple SIP servers connected back to back
  4. 4. You can always use the system as you explained as you don't need Zipato SIP server for that.
where do i find the zip server adress on the box and id and password, if zipabox ask like a sip server?...
Hi Sebastian, my concern is that how this architecture can be used in a gated community? Let's say if we have one intercom unit at the main gate (for car access), then you have 10 buildings and at each building's entrance another intercom unit that serves 10 apartments, each apartment has a Zipatile installed.
Everything is ran through a centralized SIP server from 2N.
Isn't better to offer a Zipato client as well that interacts with the 2N server (or any other SIP server)? With 2N App you can achieve the same functionality but you don't get this coupling with the Zipato subsystem (ex. run a rule when after 3 rings no one answers)
@Lazlo: try to uninstall and reinstall the 2N app. I experienced the restart issue as well but after doing that everything worked fine. You need somehow to enable mullitcasting on your server for it to work.
@ Alexus,
you can install Zoiper sip client in Zipa Tile and connect it to any sip server that will works fine.
Zoiper works fine, incoming calls when in standby etc.!
Zipato have released a YouTube clip showhow to setup zip server, it is showing in settings how to setup, but my zipabox duo does not have that setting. I'm on firmware 1.1.32 I'm now upgrading to firmware 1.1.35
I can't find in internal setting in ip, I'm the only person having this problem?
And yes I have paid for a pro upgrade.
https://www.youtube.com/user/zipatotv
SIP server only works with Zipatile. Does not work with Zipabox.
how to install it in zipatile.
He asks me to buy a credits that it's normal
Not 100% sure. It might e. Go to youtube and find zipatotv. They have video tutorials how to set up.
Unfortunately need pro licence see picture in tutoriel.
Watchout ;the last updates (intercom & sipserver) are eating you zipatile battery and the thermostat is not working anymore.
Wait for a fix.
SIP Server and thermostat are not related, they are 2 separate features, so they can't influence one another.
We are already working on thermostat issue.
Battery consumption is nominal for Sip Server and Intercom apps, please check that "Stay awake" function or some other gesture is not preventing ZipaTile screen to go off after some time, because screen is main power consumer on ZipaTile.
I think I can confirm malfunction with the thermostat. My customer contacted me today that,since the app upgrade via app repo the heating does not work. I figured it out that the problem is that the output device.does not toggle. the input and thermosmeter is.fine, but obviously this makes the thermostat unubasable. Can you check if you have same problem?
I had the same issue with excessive battery consumption after installing the new SIPServer and Intercom client. After reverting back to the previous versions of these two battery consumption is back to what it used the be for all the month before......so at least it feels like there is a relationship even thought it might look a bit odd....
SIP Server application is under optimisation process, new version will be available soon.
I have advised customer to do what you did Roland. Not sure if he will have
time today, but perhaps then tomorrow. Unless zipato will resolve the
issue in the meantime I will report back what is the finding of
customer. He does not need SIP server anyway.
I can also confirm Rolands statement. For my customer once updated those two apps the heating and the siren as sauawk stopped working. Customer reverted the two apps on zipatile and.back to normal. Now all working properly.
SIP server unresponsive and only stating Wifi connection when checking on device?
Could this be related to firmware?
Check that v1.1.1 is installed on ZipaTile and SipServer is configured on WebUI (don't forget to sync ). Afterwards everything should be handled automatically.
3
Solved! Thx. Did the update in the app repo
We have released Zipato Sip Server v.1.1. today. It should overuse CPU no more.
Sebastian, thanks for this info. Could you please confirm that the immense CPU usage indeed was causing the following symptoms:
- rules not working or only partially working
- battery draining
- motion sensors staying in state MOTION even if there is no motion for a long time
If so then I will install the 1.1 version of the SIPServer to verify at my end as well. If you have doubts please let me know as well as I will then not spend the time on testing it.
Thanks as always.
Roland
Hi Roland,
you are right, SIP server application was causing immense CPU usage, and this was causing all other apps to practically stop working, including rule engine, internal app which is managing sensors, and so on... Of course, battery draining was one of consequences as well.
I can confirm taht I have the same issues as Roland. I have updated SIP and shall see how it goes from now on
Did anybody get a doorbird to work with the Zipatile Sip Server?
Doorbird integration is currently under construction, more information will be available soon.
Currently supported and tested doorphone manufactures ("pure" SIP implementation): 2N, Avadesign, Leviton, ...
when wil the cluster get sip server?
yes, how to get one call to go to many clients, or one cluster.
SIP server cluster integration is under implementation, more information will be available soon.
I want to call my phone while not at home (remote).
İf my phone connected local wireless when I calls to Sıp server's Zipatile by 2n Helios. . It does work. But if my phone connected 3g with sim card. It doesn't called. I am doing something wrong or It doesn't work that way. Can you help me?
SIP Server provides VoIP service with plain UDP packages to connected clients. Unfortunately, lots of ISPs have restricted such communication on mobile gateways (2G/3G/4G) or even on some xDSL/Cable installations. Please try to make a phone call at least twice between remote clients and if doesn't work then for surly there is ISP restriction.
Future SIPServer & Intercom releases will be included with mechanism which will resolve ISP restrictions permanently.
Hi Tomislav, when do you expect the release to solve the ISP restrictions?
Telephony restriction issues are planned for development, but currently can not say exactly when it will be available.
@Tomislav Senegacnik
Have you released the SIP Server that resolve the ISO Restrictions
So as far as I understand the post, it is not possible to get a doorbell-intercom running on the zipatile without spending another $100 for the pro license?
Did you try the doorbird Andoid app on Zipatile? If you have to run the SIP server on the Zipatile you have to pay for the pro license. but what if the app runs correctly on Zipatile? I've made a test using a 2N Helios doorphone (described here: https://www.youtube.com/watch?v=7Gev9u0tNbM) trying to use the 2N Android client app instead of the setup descibed in the video. The 2N app runs correctly but does not ring. All the other functions (sound, video stream, door lock opening...) are ok but while it doesn't ring, it's actually unusable. Maybe the Doorbird app is different.
Intercom app doesn't have licence restriction, PRO package is required only for creation of SIP server. So, if you have, for example, three ZipaTIles only one needs PRO for SIP server creation, other Tiles can just connect to the tile with SIP server.
Thats all too expensive for testing purposes... There should be something like a trial license.
Noone tells me that it will work afterwards as expected, so I need to struggle around with 3rd Party SIP Servers like uSipServer e.g...
You can always try 2N app, Linphone or other similar apps
We tested 2N app and it does not ring. It pops up corectly even when the Zipatile screen is idle but there is no ring sound. The in-app functions are ok. You can talk, you can see the video stream, you can open the door.
With Linphone we were unable to unlock the door.
The single issue regarding the 2N client is that ringing. It should be fixed by Zipato because if you are using just a sigle Zipatile in your house (probably 95% of the installations), it is a little bit expensive to make it work as an Intercom.
The problem is not the app, the problem is the zipatile and IF its SIP Server is working correctly.
So you should give out a 30day trial to get things running. I don´t spend 100$ not knowing if the functionality really works.
@Laszlo
2N app does have some issues with communication with zipatile because it interferes with SIP server and Intercom app, but Cloud configuration should bypass that issues. You can try with that.
New IP device will ensure bringing to front Doorbird app after push notification so user will be able communicate with caller, open the door, etc. Doorbird app is proprietary IP based solution and it doesn't need SIP server. Disadvantage of this setup is that is dependent on Internet connectivity and it can not work without it. SIP however, works in offline and online state (with or without Internet connectivity), and its currently issue is that some ISPs are blocking SIP traffic so on some ISPs or countries Remote call is not available. This issue will be fixed soon, so free communication will be available localy and remotely.
@Ubuntuu
PRO licence is intended for advanced usage of ZipaTile and its available services. When you buy PRO you get all currently available services + 1 year of free upgrades. Those services stays permanent on your zipatile and can not expire (more details on https://www.zipato.com/how-it-works/features).
Company policy is that SIP server is bundled only with PRO package. If you need to test some other solutions you're free to experiment with APK installation.
@Tomislav
2N Cloud costs $2/device/month. That means $2 for the 2N doorphone and $2 for the Zipatile + Internet connection for both. Youl'll probably spend about $100 on the first year for this setup. PRO license is more cost-efficient in this case.
@Ubuntu
I know nothing about Doorbird but we tested the Zipatile SIP server and 2N Helios doorphone combo in the recommended setup and it works. But we spent $100 for a test. 2N is more expensive than Doorbird, I know. Another issue is the more complex maintenance of a large installation (more than 100 Zipatiles in a building in our case). The 2N doorphone + 2N Android client on the Zipatiles is by far more easy to manage. As you can imagine, the Cloud solution sugested by Tomislav is definitely not a solution for a large istallation. Nobody will pay a monthly fee for the intercom.
But what about the issue where the 2N app doesn't ring on the zipatile, as Laszlo mentioned.
It shows on the screen and you can answer and talk, but the ringing doesn't happen.
That needs a solution.
@laszlo
Hi LAszlo;
Did you find a solution fot the issue related to the 2N app app installed on zipatile that works (video stream, sound, door lock!!!;;;) but without ringing??
I think this solution is only working if you have only one client and one door station.
But what if you have multi 2N video door station with 100 appartments. If you simply install the app on each Client's Zipatile? How do you redirect the call from the 2N door phone to the needed zipatile!!(The zipatile n20 on appartment 20 when the guest press the button 20 on the 2 N external door phone station!!
Does that mean if we have at the building 's entery more than 1 appartment we have to buy zipatile SIP Server so that each one xwill have a name and a password ??
That needs confirmation
Doorbird app does not ring on zipatile either.
Integration by zipato was announced long ago... now expected this week?
I went for Control4 in the meanwhile.
Doorbird app doesn't ring because it doesn't have service which waits in background, it depends for push notification which opens the app.
The guys which do not get a ring from their app need to add the google play services to their zipatile as far as I know.
Correct, but this has been taken care of on Zipatile with latest versions, which will be available for update this week.
Well, I really don't want to modify dozens of Zipatiles in an unsupported manner to get an app working. Yes, installing Google Services solves the problem but will open the Zipatile to a whole range of problemes that will crash it seconds. Our last attempt ran into a factory reset and a support ticket to rejoin the Zipatile to its Zipato account. It messed up even the account settings on the cloud. I cannot sugest this solution to my clients, I don't want to be called all day long for crashed Zipatiles. I am wainting for a stable solution from Zipato.
@Tomislav: I'll bomb you with request next week if the update won't be available. Just kidding :)
So the third party apps will work in future?
Yes, there will be support for 3rd party Intercom apps (without SIP) and more robust solutions with SIP.
Allright, then I will wait some more months/years until I can use the zipatile as working door-intercom.
Thanks for the update.
@Tomislav: How? Will there be Google play services available for Zipatile?
Cheers
Mirko
Currently Google services are not intended for ZipaTile.
Hi Tomislav,
In the zipato intercom system, the apartments can clear their neighbors. This is a big problem.
For example I do not like neighbors and I deleted it from zipatile intercom application. As a result, the neighbor can no longer use intercom. Do you have a solution for this?
Best Regards,
Do you mean that ANYBODY can add or delete a user on the Zipatile SIP server, not only the user of that "master" Zipatile? If there is a Zipatile in all apartments, all off them can delete any of the users created on the "master" Zipatile? We just started cabling for 100+ Zipatiles in an apartment building. Tomislav this must be a joke.
Don't worry, apartment contacts can not delete building contacts, they're separated by controller SIP domains.
However, on single SIP server, at this moment, owner and member contacts are treated the same so member can delete owners contact. This will be resolved soon with restriction that only owner of created contact can delete it with exception that owner of zipatile (SIP server) can modify any contacts.
In short, zipatile owner will have full control, and members will have access only of their contacts.
Hi Tomislav,
I do not clearly undestand. We have a sigle SIP server on that building. 100+ Zipatiles, one in each apartment, +1 Zipatile as a SIP server. We have two 2N Helios doorphones at the gates. All are connected in the same network. Will the user be able to delete another user in this this setup or not?
If you have Building SIP server and SIP server for every apartment, then certainly no.
If you have only one SIP server and all clients connected to it, then yes.
You can see the schematic in attachment718361351a90bbd371b584c3c3ddbe9c
As we have only one Zipatile per apartment, I see no reason to install SIP server on them. There are no local doorphones which need to managed by that local SIP server. Another reason is that this will increase our project cost vith more than $10.000 for the pro licenses. I consider this a completely unacceptable security breach. Please suggest a solution for such a large scale project.
In my opinion, security breach is in setup when all tiles from different apartments are set to single Building SIP server, but as you wish. Fix for deleting contacts other then owner will be implemented in SIP server v1.3.2.
Hi LAszlo;
@Laszlo Szoke
I have a simular project with 50 appartments with one zipatile on each appartment.
How have you proceed ? HAve you bought the 10.000$ for the pro licenses for each zipatile?
What if i have a local door phone???
How have you done Laszlo?
Hi tomislav, can you explain how the apartment zipatile is connected to 2 networks. The building network via Ethernet and the local apartment network via WiFi.
My experience says that this dual network setup does not work. The USB-to-Ethernet adapters does not work while the Wi-Fi is active.
All issues with dual network communication are resolved in SIP server v1.3.1 which will be available in new OTA upgrade. Currently it is under testing and will be available for usage soon.
Tomislav, is there a desciption how to use a third party SIP server with Zipatile? In the actual situation I prefer to use a deicated server running Asterisk or 3CX just to avoid users to delete each other.
Currently, there is no public documentation for Zipato sip server. Please be patient and issue with deleting contacts will be resolved soon
@Laszlo
Please try to understand what Tomislav is saying here. Users can't delete each other in appartment building! Building SIP server is only accessible by building manager. What Tomislav is trying to explain to you is related to the appartment SIP server which you don't want to use anyway.
If you want to use any third party SIP server, you can do it. However, please understand that we don't provide any support for these SIP server (which should be quite logical at the first place).
Thank you for your understanding.
@Sebastian Popovici
Thank you very much for your intervention. Tomislav statet above:
"However, on single SIP server, at this moment, owner and member contacts are treated the same so member can delete owners contact. This will be resolved soon with restriction that only owner of created contact can delete it with exception that owner of zipatile (SIP server) can modify any contacts."
This is why I insisted on this issue. We have just one SIP server in the whole network whic is the buildings SIP server. If anyone from an apartment Zipatile will able to delete a registered user, this gonna be a disaster. Obviously we also want to restrict addition or editing of users on the SIP server. The apartment Zipatile should be a simple Intercom client with no rights. If you say that we do not need to spend a lot of money for Pro licenses and the users won't be able to mess up the system, I'm really happy. To be sure we talk about the same thing, here is our building:fa1b94dbbc456bf67c5c4457d172a330
@ laszlov
what if we have local door phone in front of each appartment will this schematic works as well?
And I guess this means you can't run another sip inside the apartment.
