Same device, different clusters
Jasper Simmer shared this question 10 years ago
I have multiple smokesensors (fibaro) and multi sensors (fibaro). But they are installed differently. For an example i've attached the file sensor.png which shows to similar sensors with different clusters. One show X, Y and Z acceleration for instance and the other doesn't. How do I know which version is correct and how do I get them all to install in the same way?
Replies (7)
yes i had similar issues with these, also the aetoec multisensor 6.
And while i'm at it, why is the Fibaro Dimmer 2 so difficult to include? It also finishes inclusion process with device not configured, but if you do a refresh of the system it is displayed.
Glad to hear I'm not the only one :) But have you found a solution?
contact support, they fix everything
Dear Jasper,
We have corrected device descriptor for Fibaro smoke sensor and implemented on your device.
The things with Fibaro motion sensor are the little bit complicated and they still working to resolve this.
Pero
Thanx for the update
Any progress on the multisensor? It hasn't registered anything since the 26th now.
same problem here, opened a ticket for fibario multisensors, old ones, and new zwave plus ones.
also I have a aeon multisensor 6, and an old big one gen 4, zipato 4in1 sensor. and all have strange behaviour. not logging motion. or motion stays on for hours. etc.
no reaction on the support ticket. since 30 june :(
The motion sensor 6 for me works fine, as does the 4in1. I did find the motion for aeotec 6 stayed on to long and had to change the delay time and the sensitivity. I'll check out a fibaro motion today and get back to you
my 4in1 and fibaro's worked fine before i lost half my devices, had to rejoin then, and after rejoining they were messed up.
at the moment the fibaro's not even showing the status in the android app.
they are working on it.
double post..
Whats is the status of the work on the fibaro motion sensor? Any progess?
