white value for turnable globes in rule maker
Adrian Van Der Heijden shared this problem 10 years ago
it would be great if we could get the white value of a globe? We can get all the RGB values but not the specific white level. The reason, I would like to be able to adjust one Osram lightify globe, and the whole group in one room follow this colour. I can set the RGB values and copy them to other globes, but not the white. The white values simple comes up as 000000. No matter if it is warm or cool white.
Same here for the Zipato RGBW bulp.
Well not quite, for the Zipato RGBW bulb you can only control 4 channels out of the five (RGB and warm white led). the Cold white led is not controllable.
Check this:
https://community.zipato.com/topic/zipato-rgbw-bulb-how-to-control-the-cold-white-channel-in-rule-creator
you can control the white channel, just manually in the app. I guess you mean by code, then yes, every white setting goes to warm white. This is what we mean, we need this control.
