valve actuator
mehrpaad shared this question 10 years ago
how can i controll a valve between 0 and 100
witch module i need? and can any one send me diagrams?
to control what? Is the valve already connected to your controller? If so just create a virtual meter.
Or do you want to know what type of module to use to control the valve? Depends on the valve, what brand/type is it? Not sure if a motor module or a dimmer would work.
control electronic valve with 2 wires
i want to control it between 0 and 100
can i use a MM motor philio?
@Mehrpaad,
In order to get an answer to this question, you must provide more details on your valve. If you only have two wires, it sounds like it is a solenoid type valve which is either completely closed or fully open. If so, the question is what voltage the valve needs to operate. Please provide the manufacturer/type/model and I am sure someone will provide a functional description.
Robert Hercz
