Motion detector doesn't trigger rule again
Thorsten Roth shared this question 10 years ago
Hi all,
I created the following rule:
4d1cce7577dc2f21cde2a76673271974
As you can see, very simple. I have two motion sensor and when one of them is triggered, the light should turn on. For my understanding, every time when one of the sensors see a motion, the wait time for 90s should start again, isn't it? Or is it required to handle this state different, like if(dimmer is >50) then Wait 90s ?
I also thought without a JOIN block the same action will triggered again, or in other words my current rule should work?
Thanks,
Thorsten
Your rule is correct but in theory it will not restart the timer if it changes from NO MOTION to MOTION. You need to use a JOIN block between the when and the first IF.
Thanks! Like that:
254119b5791d684c047af2c14e4fad9b
also it will be determined by the re trigger time interval set on your device. Consult your manual for this information.
