Server Probs?
Senad shared this problem 10 years ago
Have anybody Problems with The Server of Zipato ? My Box doesnt work correctly (States are wrong or freeze and Push Notifications unregulary) After Update from The new Firmware...
I find The Problem !
The new Firmware doesnt work correctly ...i have make a downgrade and The Box Works normally with The States and The push Notifications !!
Which FW?
FW 1.0.17....
Sorry, I mean the FW 1.1.22 !!!!!! not the FW 1.0.17
I also experienced some different kinds of problems with 1.0.22, I was prevoiusly on 1.0.19 which worked fine.
How do you downgrade to a specific FW version, I got 1.0.17 when doing official but how to install 1.0.19 ??
Problems with 1.0.22: Rules did not work, PUSH did not work, very slow response on 433 mHz devices...
This morning, all lights were still on, AC was not started, no PUSH from temperaures in refrigerators....etc..
Br
Torbjorn
We have found the server issue with the 1.0.22 version. Be free to try again now...
Is there still a problem with the PUSH functionality..???
All my roles where a PUSH message is to be sent does not give me any messages...
Br
Torbjorn
i cant disarm, not in webgui or from andriod app.
989e28b2d8138e3200e8cdcd81c78ca4
1.1.22
I also have hade trouble previous today that rules does not execute
I uppgraderad to this beta due to new created rules did not execute. Seams i did go from bad to worse.
Hi Nicklas,
Have you earlier tried to create a Cluster ??
well not lately, i most likely pushed the button at some time but not in this firmware release
Nicklas,
Look carefully at your FW version: Does it say 1.1.22 ??
Mine do that as well.
I think this FW is for cluster boxes while 1.0.22 is for stand alone boxes.
I tried clustering in the 1.0.17 release and got a cluster ID.
I think this is the reason why we have problems.
I have put a ticket at support about the issue....
Torbjorn
I'm now totally stuck with my Zipabox.
FW is 1.1.22. I think this is the cluster FW....??
No rules execute
When a Scene is run, nothing happens.
Toggeling each device manually ON/OFF in browser works fine.
I have submitted a support ticket
Br
Torbjorn
