Zipato 3in1 Sensor dosnt show open/closed state
Simon shared this problem 10 years ago
After successfull adding serveral sensors the last 3/1 sensor is not showing the open/closed state in the tile. The field is just empty. On the web UI it shows closed all the time. Temp and Lum is updating fine. On the web ui if Looking to the temp field there are three buttons :temp lum and state. In this field the open/closed state is showing correctly.
Is this just misconfiguration? Id did nothing different to the other 5 sensors?
Deleting, reseting and readding did not changed the behavior.
Any Suggestions are welcome.
Thanks simon
Hi Simon,
I have the same issue. Which firmware release have you on your tile?
Thanks,
Ivica
Greetings,
Please open tickets on our support site, thank you.
running on Firmware 1.0.18a, will rise a ticket
Simon
