Fibaro smoke sensor - advice required on state
Attila Hajdu shared this question 10 years ago
I have a question. Does anyone have so in depth knowledge of the fibaro smoke sensor that can answer this:
What does it mean that the smoke sensor approx 3x in one hour beeps and blinks red? The battery was replaced, however after a week the same problem came back.
When we test is based on the manual, the green light comes up, but despite every hors approx 3x beep and red blink.
There is nothing about this in the manual.
Greetings,
Try to change the wakeup interval, see if it makes a difference.
Do you think I should increase or decrease the interval?
Try to increase it.
I have the same issue time to time, it is quite annoying. I think, that it is warning about the connection is lost to the controller (this case Zipabox). It is reasonable, when Zipabox is without power, if then it is beeping. But if everything is up and running, it tells something wrong. At first I also thought, it was empty battery, but no.
