If I want to resell my Zipabox is it sufficient to factory reset and then "clear owner"?
Andrew Morsillo shared this question 10 years ago
If I want to resell my Zipabox (for example to switch to a Zipatile) is it sufficient to factory reset and then "clear owner"? Are there any other steps needed to ensure a new owner would not have problems setting up the Zipabox?
No u need to email support and tell them to remove your account so it I sent connected to the box serial number
You can do that but as you suggested it is enough. Once you completely reset the box and then you do a clear owner it logs you out and the box SN is freed up again.
Yes, it should be enough to just do a factory reset and clear owner afterwards.
Cheers,
V
