Need help with Micromodule switch double
Hi everyone,
I got an issue with the Micromodule switch double (PH-PAN04).
I connected it and installed it on my eedomus box, but I cannot control individually each relay.
It turns on and off both relays or just number #1 but never the #2.
I tried to change parameter 3 (selected endpoint) and 10 (existence of endpoint3) but without success.
Has someone faced that issue ? Is there anything to configure by default to control individually the 2 relays ?
Thanks in advance for your help !
Fabrice
Well, the device has a number of end points as any zwave device (or usually most of them). Im not sure how to use eedomus but do you have these or just a single device?
