Aeon Labs multisensor 6 - LED turn off
Attila Hajdu shared this idea 9 years ago
I have my first customer asking if there is any way to turn completely off the LED on the sensor.
Does anyone know if it is possible or not? If not I guess he will need to cover the LED with something as this disturbs his wife.
Thanks for any advise.
Replies (6)
Not possible as Aeotec does not offer an interface achieve this. A white tape should do the job
Thanks for the confirmation.
Greetings,
Setting paramater number 81 to 1 should disable the led indicator.
I've never seen this parameter before in the Aeotec official param list. Da you have any updated manual from Aeotec?
Hi Marko. It does not work. I have set up as parameter 81, tried all bit sizes and value as 1 and it failed. When pressed retrieve also nothing.
Anyway thanks for the advice
