Using Fibaro FGD212 switch in rules
David Nguyen shared this question 10 years ago
Hello !
Is there a way to use the switch in a FGD212 module in rules. I would like to get an event when someone pushes the wall switch attached to the module. Even better if I can differentiate between single and double click.
I can see the module in the rule creator but it contains the level of the dimmer and the consumption values, not the state of the switch. I did a workaround testing if the level is not zero, meaning it's on. But I would like to have more control:
- switch wall -> turn on the light + trigger a rule
- dimmer control through the app -> just turn on the light
Is there a way to do this?
Thanks!
