Enocean Trio2Sys Outdoor Light Sensor
David Pritchard shared this question 10 years ago
Is the Enocean Trio2Sys Outdoor Light Sensor supported?
Replies (7)
Put it another way: if I bought one, could it be made to work? :-)
Greetings,
We need to know which Enocean Equipment Profile this device implements.
I'm pretty sure it's A5 06 01
We do support this profile but it was never tested. So you should have no problems with actually adding the unit but there is a chance that the readings might be off. But this is something we can easily fix once you have it joined to your box.
OK excellent! Thanks.
I've just got it working. I'm not sure if "auto-detect Enocean device" is a new addition - I'd swear it wasn't there before, but I could be wrong. Anyway, using auto-detect, the device is found successfully. You then have to use Device Manager to hide "Luminance Sensor" and show "Luminance" in Device Browser to get the lux value.
Many thanks!
I spoke too soon. It's visible in the Zipabox but always shows 600 lux so far... I'm not sure if it's a battery charge problem but it's been out in the sun for a long time. I don't know where the problem is.
