Z-Wave controlled Relay - Anyone?
Robert Hercz shared this question 10 years ago
Does anyone know of a general purpose relay which is controllable by Z-wave?
I need to switch low voltage and would like to avoid having to connect a secondary relay to a standard power relay...
Brgds
Robert
3
Robert,
As far as I know this is the only dry contact relay in the z wave market, all others are either 230/110 Vac or 24 VDC. This one allows you to change the power supply. Qubino has also 230/110 Vac single relay and double relay versions, I have a few of the these and they work pretty good.
http://qubino.com/products/flush-1d-relay/
Thanks, that will do the job.
I also saw they've got a device with 2 dry contact relays :-)
